Junior - Brazil
Flight distance : 476483 ft
Brazil
DKFCan, the GPS system has the function of informing the location of your device on the globe, as well as the compass, the direction that is pointed on the globe, that is, whether it is pointing to the north or south, for example. Without the compass on the smartphone calibrated or if it does not exist, the DJI Fly app will display a smartphone design in red and and a "x", not showing the aircraft's position and direction.
In some tests, devices with low memory tend to slow down the application, even crashing or closing abruptly, especially on Android.
I had a Samsung J7 Prime, had 3GB of RAM and 32GB of memory, originally came with Android 32 bit and through ROM update performed by a friend, with Android 9 64 bit, I downloaded the DJI Fly and it worked normally, but, it closed in mid-flight, which made me change my device ... As a suggestion, I could try to download the app on Google Pay, but if you can't try to download your APK and install it, if you have difficulty, let me know, I will try to help. |
