Defective Battery
1394 14 2015-6-17
Darkfito
Defective Battery
I have a phantom 3 Advanced. Yesterday upgrade to 1.2.7 firmware and had 100% of battery life.
I have flown today and had only 78% of battery life. The battery appears defective. Only 12 loads.
It is not normal.!!!!
2015-6-17
BobbyB
Did you have this battery in the P3 when you updated the firmware?
2015-6-17
Darkfito
BobbyB Posted at 2015-6-18 00:42
Yes, I update all yesterday.
2015-6-17
Darkfito
The battery is not swollen
2015-6-17
BobbyB
I'd discharge it fully and recharge and see if that changes anything.  If not, then get a new battery and send that one in for warranty repair.
2015-6-17
Darkfito
BobbyB Posted at 2015-6-18 00:57
I'd discharge it fully and recharge and see if that changes anything.  If not, then get a new batter ...
How it is completely?
About 4% ???
Thank you
2015-6-17
Daninho
Darkfito Posted at 2015-6-18 00:59
About 4% ???
You have 300mah left on that batterie, you sucked it down under 8% i guess?
2015-6-17
BobbyB
As far as it will discharge.  Also, check your discharge delay in the app.  See how many days it is set to discharge.
2015-6-17
rholland
Flight distance : 105377 ft
BobbyB Posted at 2015-6-18 01:17
As far as it will discharge.  Also, check your discharge delay in the app.  See how many days it is  ...
from using lipos in planes and helis, I thought discharging to or below 3.3 volt per cell damaged the battery?
I also really wonder if there is a balancer built in here someplace, only way to MAINTAIN each cells health. bleeds off voltage on higher volt cells till lower volt cells catches up?
2015-6-17
BobbyB
rholland Posted at 2015-6-18 02:09
from using lipos in planes and helis, I thought discharging to or below 3.3 volt per cell damaged  ...
Ok, don't listen to me.
2015-6-17
aburkefl
Flight distance : 78612 ft
BobbyB Posted at 2015-6-18 02:46
A typical plane/helo LiPo battery discharged too low often results in a battery that cannot be charged again.  Sometimes, you can "jolt" them with a quick charge, then a balanced charge, but, if they get really low, many chargers will refuse to charge 'em again.
I'm curious in the picture of the battery screen above - the total capacity looks like it's significantly below the rated mAh of the P3 battery. The one I just charged shows 4480 mAh.
2015-6-17
BobbyB
aburkefl@gmail. Posted at 2015-6-18 09:20
A typical plane/helo LiPo battery discharged too low often results in a battery that cannot be cha ...
See...I told you not to listen to me.
2015-6-17
Darkfito
Tip: The post by the administrator or moderators shield
2015-6-18
Darkfito
Darkfito Publicados en 06/18/2015 16:12
**** Los mensajes están protegidos ****
Una vez más la vida de la batería con 100% ????
What's going on?
2015-6-18
DJI-Bruce
The gas gauge inside the battery will update the capacity of the battery from time to time. From the picture you captured, I didnt see any obvious problems with the battery, the cell voltages are in good balance. Please try to fully charge/discharge the battery and leave it idle for 24hors to let the gas gauge CI to update the capacity. Then check if the battery capacity will go back to a higher value. If not, please try contacting DJI support.
2015-6-18
