ebea
Flight distance : 4297572 ft
Denmark
The Duck Posted at 7-4 07:59
All antennas, including Yagis, are passive devices. You don't need active components (amplifier) for antennas to work and it is possible to increase both TX and RX gain without an amplifier.
The price of that Alientech antenna is ridiculous. And I would caution anything into thinking that an amplifier will solve their range problems on WiFi based drones like the Mavic Mini.
Only Reflectors and Directors on Antennas, are to consider as passive in an Antenna! What makes the gain, is first of all, that you have defined a wavelength (Mhz) where you want the Antenna to work (thats the Dipol, which becomes the active part). A fully passive antenna, has no Gain at all, and is only for the Birds to sit on.
I don't know what it is you are pointing to, about "..What I found when I ran a small...", but I have never heard about that a strong signal received in one end, should reduce the transmitting power.
So if this should be the case, there would not be any antenna gained system who would work.
I have set up a lot of Antennas during the years, to gain signals in both 2.4 and 5.8 Ghz area, and measurements on these systems, show the effect which are the goal, with the Antennas.
It's not guessing, or any mystery, but the real thing.
And thats why I wrote, and I will repeat, that the Yagi design Antennas on the Photo in these thread, has no effect at all. They could even make it worse, at they disturb the Antenna (signal) on the Controller.
If we just as an hypothetical example, did say that they worked. How would the Antenna knows in which Frequency it works on? How should they gain the signal send return to the Mavic? This Frequency is defined by the Dipol, which are missing, AND the connecting to the Controller, which make the Antenna active. The directors could then begin to put a gain on, depends on how many you add.
I have even made an Excel calculations model, years back in time, where you can put in the Frequency you want the Antenna to work in, how long you want the Antenna (numbers of directors), material used (dimension). And then you will get an Antenna design, with size on Dipol, numbers of directors, size of reflector, and the gain in dBi, ready to print out.
And that you find the price on the Linked Antenna to be ridiculous, yes, thats your opinion. But the Antenna actually works. And then, people choose by them self, if they want spend the Money.
I use, by myself, the Parabolic system, to mount on the Controller, and they really get an extra gain, as they send the received signal back to the Controllers Antennas. |
