Recentering gimbal goes down
3137 11 2020-6-21
GaryDoug
Flight distance : 1264639 ft
Why does the Recenter Gimbal action set the gimbal to -90 degrees, straight down? I would rather it set it to 0 degrees, straight ahead. I only recently started using the gimbal offset feature and did not like it pointing the gimbal straight down upon reset.
2020-6-21
Pappy3
Flight distance : 2820469 ft
Press it again (momentarily after the first press) for 0 degrees. Agreed I wish it would reset to 0 degrees initially. But I do like and find it beneficial to be able to toggle quickly to 0 and -90 degrees.
2020-6-21
A J
Flight distance : 13864580 ft
When at -90 pressing the fn button again resets it to zero
2020-6-21
GaryDoug
Thanks to both of you guys. That was driving me crazy. I was having some problems with it because I had the light set to one press and the gimbal set to two presses. However even when I pressed twice, most of the time the light changed setting. Setting it to one press for gimbal re-centering made it much easier and repeatable.  I could not find those details in the manual so I guess it just comes with trial and error?
Thanks again.
2020-6-21
MisterFrag
Flight distance : 603143 ft
It is in the manual, on page ten where the programmable button is discussed. Maybe the description could be clearer, but the behavior is by design and correctly documented.
2020-6-21
GaryDoug
MisterFrag Posted at 6-21 11:31
Ah yes, cleverly hidden in the product profile section on page 9. But not in the actual Remote Controller features section where it belongs. How convenient.
How on earth did DJI ever pass ISO 9001 qualification?
2020-6-21
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for reaching out to DJI Forum. I am happy to know that your previous query was answered. If you have other query or concern, please feel free to post it here at DJI Forum, we are here to help. Thank you for your valued support.
2020-6-29
A J
GaryDoug Posted at 6-21 11:17
Thanks again.
You're welcome
2020-10-2
djiuser_p9IoKpFdyM3w
Flight distance : 6381 ft
MisterFrag Posted at 2020-6-21 11:31
What the manual says is "Press once to recenter the gimbal or tilt the gimbal downward."
However, if you've turned on "Allow Upward Gimbal Rotation" (which several YouTube videos recommend), the second press move the gimbal to its upper limit, i.e., +20°, rather than 0°.
2021-6-20
Pappy3
djiuser_p9IoKpFdyM3w Posted at 6-20 15:19
My MA2 doesn't do this. First press is -90 and second press immediately after reaching -90 returns the gimbal back to 0 degrees even though "Allow Upward Gimbal Rotation" is enabled.
2021-6-20
JimDandy
Flight distance : 144649 ft
They are based in....... Never mind.
2021-6-22
GaryDoug
Right...the first letter in ISO is for International ;-)
2021-6-22
