Has Anyone dared try the emergency stop in flight?
12
14757 50 2020-6-26
heliaetus
Greece
I think the new firmware allows CSC only if it detects an anomaly, I never used it and its use under normal conditions is dangerous and irresponsible
2020-7-7
Gregory.Opera
Flight distance : 151122 ft
hallmark007 Posted at 7-4 17:02
That sounds constructive. You need to remove your foot from your mouth.  LMFAO........
I'm not the one sitting here having a go at everyone... Seriously dude, stop trolling.
2020-7-9
hallmark007
Flight distance : 9827923 ft
Gregory.Opera Posted at 7-9 01:21
I’m not having a go at anyone, that was left to you, I’ve explained exactly what will happen , you on the other hand offered nothing.
2020-7-9
Sean-newbie
Flight distance : 15997 ft
A couple of days ago in ''emergency only'' response mode and sport flight mode I did a 12-13 sec CSC position from 75ft down to an indicated -2ft and the motors didn't stop. From my perspective the fall actually slowed down as it approached the ground so I am assuming the VPS  system kicked in, I released the sticks at maybe 2 to 3 ft off the ground and the fall was halted at about 1ft above the ground. I haven't looked at the flight logs yet.
FOR CLARITY
Do not try this as an experiment, I am/was prepared to lose/crash the drone but didn't think I would and was correct but, again, do not try this as an experiment.
2020-7-11
Denndb
Flight distance : 914688 ft
Croatia
Hello,
I have DJI Mini2 and if I choose "Emergency only" option for motors emergency shut down, please can someone explain in which concrete situations will that "emergency only" scenario be activated?
For instance - if some motor fails (stops spinning) and the drone starts to act uncontrollable - would that be an "emergency only" activation scenario?
2021-5-26
FriedChicken_II
Flight distance : 721555 ft
Japan
Denndb Posted at 5-26 00:50
Hello,
emergency only is judged by the drone's firmware. when it detects a collision, or the atti angle is too large, then you can use the CSC to stop motors.
2021-8-22
djiuser_iS37wQ6U9WP8
FriedChicken_II Posted at 2021-8-22 00:22
Hi, is this mean that If while flying the drone I decide to navigate the drone in a direction where the thumb sticks are the "emergency stop" the drone will not stop if everything is ok? I`m new with DJI Mini 2 SE and I got confused when and how the emergency stop is working.
2023-5-13
Sean-bumble-bee
Did you read the thread?
If the option is set to "Emergency only " the CSC position WILL NOT normally stop the motors with the drone in mid air, the drone will descend in a controlled helix until the joysticks are released and then the drone will hover.
If however you set the option to "Always" the CSC position WILL stop the drones motors after the CSC has been held for somewhat more than 1.5 seconds which is too short a delay to be safe, so your only safe option is to fly with the option set to "Emergency Only".
2023-5-13
Bashy
Flight distance : 2354357 ft
djiuser_iS37wQ6U9WP8 Posted at 5-13 12:47
There really is no need to put the sticks into that position though, not during flight anyway unless you intend to shut off the motors.
The only time, other than on purpose this would happen is if you were literally being silly with the RC sticks, so don't be silly with the sticks as it achieves nothing with flight cause it will not do any stunts.
2023-5-13
Sean-bumble-bee
Bashy Posted at 5-13 17:35
Bashy, this might interest you
https://forum.dji.com/forum.php?mod=viewthread&tid=290600
Title =  "Qu for DJI, unwanted extreme climbs & "Anytime" CSC ? "
In the Mini 3 pro forum.
2023-5-22
Bashy
Sean-bumble-bee Posted at 5-22 05:47
Thanks, will take a look
2023-5-22
12
