frankymusik
Flight distance : 27841053 ft
Since I flew from home, I was able to insert the battery into the charger shortly after a long flight (approx. 26 minutes flight time) (I use the 3-way charger of the Fly More Combo).
The battery had a residual charge of approx. 10% (according to the display in the DJI Fly app). The battery felt a bit warm after being removed from the MA2, but never hot ...
However, the battery indicator of this battery remained dark after being plugged into the charging adapter.
Removing the battery and plugging it in didn't change anything ...
I now felt that the battery was dead ...
I now waited about 10 minutes after removing the battery from the adapter. Then I put it back in the charging adapter and the charging started immediately (all 4 LEDs of the battery light up briefly, and then the first LED flashes cyclically ...
So everything is okay again ...
Is this behavior known, normal ... ???
Frank
