Dr. Yuan Shenghai
Singapore
The Manifold 2G is a TX2 variant
Be default, it can grab image from DJI cameras by OSDK ROS 3.9.
Then based on image, you can run darknet Yolo or other learning or non-learning model for actual running tasks.
by right you just need to follow this post to run. https://developer.dji.com/onboard-sdk/documentation/sample-doc/advanced-sensing-object-detection.html
But often you encounter problem such as
Failed call to cuInit: CUDA_EROR_NO_DEVICE
KerneQAM0QAM0QAM0QAM08HM18Nf45+GP8X//0MBeNbBnQ3HPuf0fX42kx3FcpWsAAAAASUVORK5CYII=[/img]
CUDA Error: __global__ function call is not configured:
In this case, you need to be in super user mode by just calling
sudo su
then
source ./catkin_ws/devel/setup.bash
or use other framework tests the resources, you should be able to run
