Geomaticist
Guille_Meinero Posted at 7-3 07:45
Hi, i have tried and compared RTKLIB and other software that make a PPK between drone rinex and a base station (public and my own).... The main problem i see is basically the interpolation to calculate the position of the drone... if you process a 1 sec raw data capture, in the worst scenario you will have 1/2 sec of uncertainty... if the drone is moving at 13m/s you will have 6.5m error (in the worst scenario).
Please correct me if i am wrong
um. if done right there is a mark (time) that occurs when you take the picture. This will not ever be at the actual GNSS epoch that is processed. so you interpolate between. usually using linear. You assume a constant velocity or whatever. But the actual GNSS epoch is solved by processing, PPK, or RTK. And that has its own time stamp. So the mark is used to compute the in between. Now if your epochs are far apart then it gets more of a guess when you extrapolate the position of he mark. but … it is NOT the error you seem to mention. At time T = 0, 1, 2, 3, you get GNSS positions at the those times (epoch). The camera fired off at T = 0.005, T= 2.652 etc. You draw a line between the time at 0 to 1, and at 0.005 that is the position you assign that mark, and it will be what you assign the image taken. But you also want to account for the offset from the GNSS sensor on the drone to the actual camera. That info is in the manual.
Decent PPK software will do this. The on board RTk does this, and also accounts for the offset. However if you PPK, you need to do the offset still.
So fly at whatever speed you need to. now, if you are using 1 second GNSS data from a public base, it will work, but you probably will get better results from a 0.2 second logging, if you use your own base. Again this only matters if you are doing PPK. If you do RTK it is different, and it is a matter of how often updated RTK corrections arrive. I don't think those need to be as frequent though, because an rtk correction is not going to change drastically in a short time.
the clock on a GNSS is very good.
