DJI Fly app Editing on iPad Mini
4901 39 2020-7-4
Kurt Air2
Flight distance : 205823 ft
Editing on the Fly app is weird on the iPad Mini.  There are blank black spaces on both ends of the video, but when I hit "Play", there is video in the black space.  When I hit "cut", the cut shows up in a location other than where I want it.  When I attempt to edit on my iPhone, it's fine.  The problem is only on the iPad Mini.  I've deleted and uploaded the app a couple times to see if that worked.  Nope.  The attachment is a screen shot of the editing page.  The black space at the front actually has video in it, and the arrows show where I attempt to "cut", and where the cut showed up.
Is this s a known problem?  ARe there others that have this problem.  I really like the larger screen; it's a bummer that it doesn't work right.  Thanx for any help.
2020-7-4
djiuser_6J9I67cwuRUL
Flight distance : 157339 ft
I’m having this same issue with my iPad Pro, so annoying! It seems like a glitch with the iPad app to me.
2020-7-5
Kurt Air2
So, if someone else is having the same issue on an iPad, it’s a glitch in the APP.   Thanks for confirming.  It’s a shame; it’s actually a nice easy editing app.  DJI should figure it out. Flying with the iPad mini for a screen as awesome, much nicer than a phone screen.
2020-7-5
DJI Paladin
Flight distance : 318 ft
Hi. I am sorry for the trouble this has caused. With regards to this concern. May I know that exact model of the iPad Mini please? Kindly please try a different recommended mobile device to isolate the issue. In addition, I will post a an image below for the recommended mobile device lists. Please keep us posted for further assistance. Thank you.
2020-7-5
Kurt Air2
iPad Mini 5 iPad. iOS 13.5.1, the most current update.
Editing works perfectly on 2 different iPhone 11‘s.   Have deleted and reinstalled Fly APP twice, have configured all software on all devices to most current releases. The issue is consistent; the same glitches occur in the same manner and in the same locations.
It seems to be an iPad-centric issue.
2020-7-5
Kurt Air2
DJI Paladin Posted at 7-5 22:47
[view_image]
I can post a screen recording video of the editing process if that helps.  It’s very strange.
2020-7-5
DJI Paladin
Kurt Air2 Posted at 7-5 23:02
Thank you for the additional information, yes please that will be a great help for this concern and please try a different recommended mobile device to isolate the issue. Please keep us posted for further assistance. Thank you.
2020-7-5
Kurt Air2
China
It works fine on 2 different iPhone 11. It does not work on iPad Mini 5.  iPad Mini 5 is not on the list you provided, but I don’t know why that would matter as the iPad OS is the same as others  that are on the list.  I am guessing the most current iPad OS upgrade (13.5.1) causes the problems.  It works (edits) fine on multiple iPhones 10 & 11. The problem is only with editing on the iPad.  It’s compatible and operates the aircraft perfectly.
2020-7-6
djiuser_DNpiJFEj1hi1
I’m having the same issue on my iPad Air 2 with the latest update.
2020-7-6
2020-7-6
2020-7-6
Kurt Air2
djiuser_DNpiJFEj1hi1 Posted at 7-6 10:11
Yeah, it’s gotta be the update.  It was fine, and then it wasn’t.
2020-7-6
Kurt Air2
Kurt Air2 Posted at 7-6 11:55
Here’s a link to a short screen shot video showing what it looks like....
https://youtu.be/ljjL0M31npc
DJI Fly App Glitch
2020-7-6
Kurt Air2
Links don’t upload correctly either.....
For all the incredible tech that goes in their products, DJI FORUM IS ABOUT AT 1999 time frame....
2020-7-6
Kurt Air2
The. Video shows the black space at the front, although there is video in there.  The cuts show up as being out of alignment with the “cut line”. Also, the cuts are different sizes and located randomly.  It’s a very strange glitch.
IPad Mini 5 with most current 13.5.1 upgrade......
2020-7-6
kontrolroom
Kurt Air2 Posted at 7-6 00:21
Experiencing the same issue on the same generation devices. App works great on iPhone but the cut feature on the iPad is out of whack. Definitely a software issue with the iPad running the current iOS. Thanks for taking your time to find a solution, I look forward to figuring out how to make this work well on my iPad
2020-7-25
kontrolroom
experiencing the same issue on identical product generations. The editing app works great on the iPhone but not on the iPad Mini 5. Specifically the cut feature. Thank you for posting above a comprehensive explanation of what the issue is.
2020-7-25
danellis06460
Flight distance : 8698 ft
kontrolroom Posted at 7-25 00:33
+1 I’m seeing the same problem on an iPad Pro 11 inch.  Latest IOS.
Hopefully its fixed soon, its a nice app.
2020-7-25
Kurt Air2
Talked to Apple, and of course they have nothing worthwhile to say about it.
2020-7-25
djiuser_3TTuHy4BYvEw
Flight distance : 10207 ft
Same issue on iPad model A1893 (6th generation) and IOS 13.6. Works correctly on iPhone 11 Pro MAX.
2020-7-26
djiuser_lrY9fYLGhvBI
Same on my iPad 11 pro with IOS 13.6.  Renders it useless for editing. Following is immediately after loading the first clip.  The editing strip seems to have no relationship to the editing position.
2020-7-30
2020-7-30
Kurt Air2
djiuser_lrY9fYLGhvBI Posted at 7-30 20:14
[view_image]
Exactly.  The cut mark has no relation to the edit location.  And, it’s random.  Cuts are different sizes.
I’ve gone to just taking out the SD card and putting it all in the computer and iMovie edit.
2020-7-31
Kurt Air2
[view_image]
2020-8-1
Trabor
Flight distance : 66755 ft
Exact same issue with iPad Air v3
2020-8-22
Trabor
Trabor Posted at 8-22 04:02
Maybe buy a cheap android tablet till DJI gets their act together??
2020-8-22
oBkirneH
Flight distance : 58684 ft
Denmark
Hi,
I have the same issue on an iPad  6. generation, model MRJP2KN/A.
Currently running iOS v13.6.1
It worker previously.
Works fine on my iPhone X - same iOS version.
On the iPad it looks like the editor doesn't go in full screen. That could cause a scaling issue.
2020-8-23
Kurt Air2
Same here.  It worked, then it didn’t.  It’s got to be the last upgrade  Enough people are all having the same problem, it’s not isolated.  There’s another upgrade that just came out. I’ll load it and try the edit again and report back.
2020-8-23
djiuser_H990IHxeVIeX
Flight distance : 20285 ft
Having the same issue on iPad mini 5, editing cut lines are off and app is a square and not full screen.
2020-8-25
fans40fed5ef
Flight distance : 1693 ft
Same issue for me latest iPad Pro 11...
2020-9-6
djiuser_uwmTDudczhL3
oBkirneH Posted at 8-23 02:58
Hi,
Exact same issue on iPad 6th Gen
2020-10-6
SublimeQuad
Flight distance : 30348 ft
Same issue on iPad Pro 10" with latest iOS and latest app (.10). Maybe a better question is, "Does anyone have the latest Fly app running properly on an iPad?"
It's a good day to fly,
Michael
2020-10-16
Kurt Air2
Essentially, yes.  I’ve tried it in 3 different iPad configurations, all 2020  machinery and OS, and none of them work.  It’s OK.  iMovie is infinitely better anyway, albeit with a couple additional steps to get to a finished state.
2020-10-16
JL Resort
Flight distance : 5988 ft
Same exact problem with brand new iPad Air 4th Gen. all software are up to date. Editor works fine on iPhone 11 Pro
2020-12-25
fansb2a2e50d
Flight distance : 33717 ft
Same. IOS ver 14.4.1 mini gen 5. Cannot believe DJI  couldn’t fix this until today.
I have DJI go4 on same iPad mini, which does not have any issue.
2021-3-18
Kurt Air2
fansb2a2e50d Posted at 3-18 18:11
Is it actually fixed?  I haven’t tried it in months.  I just download and edit in iMovie.
2021-3-18
djiuser_4OEdMEcLLK8W
Kurt Air2 Posted at 3-18 18:30
It most certainly is not fixed. I am a brand new user of DJI Drone Mini 2 and as such went from Android phone to iPad Mini 5 as no android tablets were recommended but neither was iPad 5 although iPad 4 was....so silly me went and bought iPad 5 yesterday.....now sitting here very disappointed after chatting on-lint to DJI who say there si nothing we can do unless developers do some sort of software update but that they also only really recommend using mobile phones for the complete operation...I wanted a bigger screen to edit my footage on and fly the drone so thought I was doing the right thing.....can anyone recommend a non IOS user such as myself a good editing programme to use on the iPad Min5 please otherwise there will not be much point in me flying the drone at all.  Thank you in advance.
2021-3-19
Kurt Air2
djiuser_4OEdMEcLLK8W Posted at 3-19 05:57
I’m all iOS, so no recommendation from me.
2021-3-19
djiuser_Ef8MjtTj8wjD
I have the same issues on Ipad mini 4, flys the drone perfect, and live using it!, but when it comes to editing, it sucks arse! Please Dji try and resolve this issue? Already spent a fortune getting all the bits I need to fky the drone. Any news would be much appreciated
2021-4-3
Kurt Air2
djiuser_Ef8MjtTj8wjD Posted at 4-3 13:06
.....and now.... It works!  I have no idea why, but on a whim, after dozens of attempts and finally giving up, I tried to edit something on my iPad Mini 5 and it worked just like on the phone.
Who knows?  Not me....
2021-4-21
