DJI Fly App log files missing?
2956 7 2020-7-6
Mirek L
Flight distance : 609724 ft
Hi,
DJI Fly stores flight records in two types of log files:
  • .txt files in FlighRecord directory (Android)
  • .dat files in MCDatFlightRecords directory under FlightRecords directory (Android)
I have noticed that while my .txt log files are there, a lot of .dat files are missing. Some flights do have .dat files and many don't. Also, it seems that older .dat files get automatically deleted (this does not happen with .txt logs).
Is this normal? What is the logic behind erratic .dat files? Is this DJI Fly app bug which may cause absence of critical log records in case they are required for DJI analysis?
Mirek
2020-7-6
GaryDoug
Flight distance : 1122201 ft
How are you determining whether the files are there or not? When I hook my pc to my tablet, it does not see all the files. But when I run a file manager program on the tablet, it shows the "missing" files. I don't know the cause of that problem. So I just use the file manager to copy the files to the sd card so the pc can see them.
2020-7-6
Mirek L
GaryDoug Posted at 7-6 18:51
GaryDoug,
I use File Manager built into my Android device (My Files).
I see exactly the same .dat files on PC (when I connect my mobile via USB) as directly on my mobile.
When I copy entire directory MCDatFlightRecords to PC I see same .dat files.
.dat files are definitively missing and they are also being deleted.
It seems like a bug.
Will DJI be able to diagnose any issues I can experience in future if .dat files are not available?
Mirek
2020-7-7
BobWinNV
Flight distance : 270322 ft
I believe that when you sync your flights (do you have your app set to auto sync your flights?) DJI server grabs the .dat files and then deletes them.
2020-7-7
Mirek L
BobWinNV Posted at 7-7 16:34
BobWinNV,
It is possible. I don't have autosync set but I do sync manually from time to time.
However, if this is the case syncing does a poor job at removing all .dat files. It removes some while leaving others.
For example, all my recent .dat files are gone (from July 2 and July 3) but two earlier files (from July 1) are still on my mobile.
Kind of haphazard.
Mirek
2020-7-7
BobWinNV
Mirek L Posted at 7-7 17:23
BobWinNV,
It does the same to me.
2020-7-7
virtual
Flight distance : 3294938 ft
Czechia
BobWinNV,
In older app versions (with Mavic Mini) DAT files were removed when synced with DJI servers. 108 app stopped deleting files but there was option to clear flight records in phone manually (I had over 600MB of DAT files), I updated MA2 compatible app version yesterday so I have no experience with latest app...
2020-7-8
小仙女的星巴克
Flight distance : 4657841 ft
I had 2 of my recent flight logs missing too for MA2.  However Airdata have it.
2020-7-8
