Hey everyone, new here. My apologies in advance if this is not the way to go.
I recently purchased a Mavic Pro (the first one) second hand from 'a friend'.
Today I received some new propellers and accessories and decided to give it a test run again.
For some reason, the footage is artifacting/glitching/showing weird behavior and the footage is crooked as well. (You won't see the crooked bit because I straightened it out in post... my bad... gotta trust me on that one).
For reference here is a small bit from the video:
I feel really stupid for buying this drone now since I for some reason didn't see the problem when test flying it with the guy. Is this problem fixable or is this a gimbal/camera issue? The guy told me he never crashed it but I have my doubts about that now.
I tried re-calibrating everything including the auto-camera calibration, didn't help.
Thanks!
EDIT:
Woe Posted at 7-7 09:12
What SD card are you using? Also have you tried formatting it .
Is this footage from the SD card or a cache version from the phone?
I am using a Sandisk Extreme 32GB V30 HC1 class 3? If I am saying that correctly. Here is an image of it: https://static.bhphoto.com/images/images750x750/1497354526_1343701.jpg
Tried formatting it yes, no luck.
The footage is from the SD card.
Hi there, thanks for your reply!
I would factory reset the drone in Assistant 2. Download and reinstall the firmware on the AC and RC using Assistant 2. Then calibrate everything (IMU, RC, Gimbal via the app and OA via Assistant 2). Reset the camera, format the micro SD card as Woe said then calibrate the compass when you arrive at your flight location. Don't use any ND filters to start with and see if it happens again. If it does then go and pay your 'friend' a little visit and get your money back!
A J Posted at 7-7 11:17
Hello there,
Currently in the process of going through everything you said. Calibrating as we speak. Will let you know how or what when I have more information!
Good for you. It may be anything causing it so doing the lot will cover off all the bases and there will be nothing else you can do except return it or send it to DJI for repair - which won't be cheap! Fingers crossed all of the resets and calibrations sort it out. The MP1 was a revolutionary, amazing drone but notorious for its bugs and glitches.
A J Posted at 7-7 11:46
Everything is done except the compass calibration. It seems as tho the camera is still at an angle when on a flat surface... I will be sure to test the drone tomorrow since it's already dark out where I live. Thanks for the help so far, I really appreciate it! I will keep you updated on the findings!
djiuser_epGY4F2xOmAz Posted at 7-7 12:10
Check the ribbon cables on the gimbal to make sure it's in tack.
Just checked the ribbon cable, all seems to be just fine. No tears or damage to be seen. I might take some high-res pics later and post there here to make sure I am not missing anything.
ScreemS Posted at 7-7 12:28
Thats a good idea - make sure the drone is on a flat surface you you calibrate the gimbal - you can also make manual adjustments too via the app.
A J Posted at 7-7 12:32
Here is the album link to some of the images. If you need any other angles, or other images make sure to let me know!
https://imgur.com/a/bUHCzZv
ScreemS Posted at 7-7 13:03
Hate to say it but after doing all of those calibrations and rests if this is the end result it unfortunately looks like a hardware problem with the gimbal motor. The gimbal is clearly offset on start up and given the issues you had with the footage it is obvious you have been sold a defective unit.
You have three options IMO:
1. Repair it if you know how to strip it down and fix it yourself. If you don't then do not even attempt it.
2. Send it to DJI for repair - they will probably just send you a refurb unit but at least it will work - then forward the bill to your friend or pay it yourself (you'll be talking three figures)
3. (this is what I would do) - go back to see your friend, give him back the drone and get every penny back that you gave him. If he refuses then seek legal advice but that will obviously end the friendship though no friend of mine would ever even try to sell me something that was discreetly broken!
A J Posted at 7-7 13:12
I have yet to test fly it after doing all the calibrations. I will be testing it tomorrow and if it still occurs I will be knocking on his door. Thanks for all the help.
ScreemS Posted at 7-7 13:17
Well, that ff-ing sucks :/
No probs - put it in the air and test it though if the gimbal looks like that on the ground whilst the drone is turned on then it ain't right mate. The lens should be pointing straight ahead. Don't fly the drone around for too long either as there may be other issues you are not aware of and it'll be just your luck that it crashes then you can forget getting your money back... He probably crashed it himself, damaged the gimbal but realised it still flies then saw you coming... Be nice!
A J Posted at 7-7 13:29
Oh, in the pictures it was turned off, my bad. It was on its back and turned off to be precise.
Here is a video of the gimbal startup (Sorry for the shaky footage, only have 1 light in my room and had to use it, lol):
Hello there ScreemS. I am sorry to reach and to know that you are having these issues with your DJI Mavic Pro. Since you have done multiple troubleshooting steps that were given by A J and Woe and still the issue persist. I would recommend you contact our support team to start up a ticket for the said drone https://www.dji.com/support?site=brandsite&from=nav . We have the professional team who would do their best to fix and then the corresponding resolution would be provided. Please note that the repair will depend on the warranty period of the said drone; otherwise, valid charges will apply. Thank you.
Yeah, the way the gimbal seems to crash into the drone on start up also didn't seem right too - give it a test but as others have pointed out this isn't 100% TBH.
The issue still persisted after all the steps taken above. I listed the drone as 'partially broken' online and explained the problem it was having. I listed it with all the accessories and my DJI goggles racing edition. Soon after a guy contacted me saying he fixes mavics for a living and he would like to purchase the set. I ended up earning an extra 50 euro's more than what I bought it for, so in the end... Not bad!
