Raudi
I was enjoying my first flights with my new Mavic Air 2 (fly more combo) purchased today after watching some great first flight video's and beginer's guides linked here.
After 10-15 minutes into a short distance flight above my neighborhood the video feed started stuttering / freezing for several seconds at a time making it difficult to fly. I did not have any signal loss or other warning signs of a degraded signal (full bars) and was able to maneuver back to home OK. Even with the drone hovering right in front of me and doing some simple maneuvers, turns etc. the video feed was still stuttering / freezing really bad to my Iphone X (wifi off). I tried another flight an hour later later with a different battery and also set the transmission setting to "smooth" instead of HD to see if that would make any difference but the same issue occured after around 10-15 minutes of flying again and continued through landing.
I did notice the bottom of the drone was pretty hot after returning and it is 100+ degrees here today so possibly overheating? The internal camera footage looked normal after reviewing except I could tell where I slowed / stopped flying when the stuttering was occuring to see if it would clear up.
Please let em know if anyone else has experienced a similar issue and suggestions to try as I plan to wait until it's cooler outside later this evening or in the morning to try again.
Thanks for any help!
