Neptune99
Geebax Posted at 7-12 21:19
The video file is exactly the same whether you use MP4 or MOV, it is only the 'container' holding the file that is different. The MOV format was a fop to Apple, because Apple thought it should have its own unique form of video file. But Windows, and most Win applications will handle either. Best to stay with MP4.
And no, you do not need to convert any file, VLC will play them without problems. However if you are using an older video editing app, you might be wise to steer clear of recording in H265.
Thank you, Geebax, for your help. I appreciate it.
I was also wondering about a slight issue I had during my first flight the other day. I intentionally started a quickshot orbital that would have a tree in its path, basically to see the obstacle avoidance system working. It did stop the drone at a safe distance, but made no corrective maneuver to get around it, she just hovered in place. My question, is that normal ? also it would not take stick input to move away from that tree and I am not quite sure what I did to finally get it to move. Is it the red pause button on the controller that would end the quickshot program and give me control back, or what is the best way to stop a programmed sequence and get stick control back immediately. Thank's again for any help on this. Have a Great Day ! |
