Good evening, I am reaching out in order to fix an issue with the P4M that has happened over the past two months. With the GS Pro Version 2.0.11, you no longer have an ability to do 1 sec capture interval, like you did in version 2.0.10. This causes you to use a 2 sec delay to even start the mission on the P4M and cuts your coverage area/time in half. So now what used to take one battery takes 1.5-2 batteries when covering say a 40 acre field. Therefore it cuts a total coverage of say what used to be 4-500 acres a day down to 2-250. When I was demoed and tested this aircraft it had the capability to do roughly 40 acres a battery which was sufficient. However, 2 batteries for 40 acres is unacceptable in the world of agriculture. Please advise on this situation thank you. -Rich
