cheddar-man
Flight distance : 44062 ft
Ummm, I can see absolutely no advantage of heating the internal PCB';s with a hot-air gun unless there is evidence of moisture in there.
Even then I would only address the situation by dabbing all the PCB's with a soft cloth with WD40 (or similar) on it.
He did no tests on the battery itself to check its residual voltage.
You might want to check the battery voltage, just open the RC, unplug the battery and check its voltage. It is a two cell LiPo so should read between 3.6V~3.9V per cell - 7.2 - 7.6v
If your battery shows below 6v (3v per cell) it has been discharged below its minimum recommended level and needs replacing.
There are several places on line where you can buy replacements and also videos showing how to do it.
Having said that, there are methods of reclaiming such batteries but it can be dangerous and I personally would not recommend playing with it. Buy a new one. |
