Kevin Armstrong
MAPilot Posted at 2020-7-31 21:37
Thanks for responding quickly!
Unfortunately, the version you have at the link provided is the current one, which has had several functions removed (related to user editing of main.js), relative to v1.1.2 which I have installed. I have had v1.1.2 installed on this computer several months ago, and working fine, but updated to the then current version. When I found out about the deplenishment of some functions, I removed it, and installed v1.1.2.
Hi, I run an original Mavic Air, around four years old, if you download the Assistant for conmsumer Drones the USB won't show connection, and gives an 'incompatible with' message.
So got through on chat with Europe technical and a lady kindly passed the link for the earlier version, which works fine, so could do the adjustment routines for the rear and downward sensors
The version given that worked on mine is DJI+Assistant +1.2.5.exe
Kevin Armstrong
