virtual
Flight distance : 4897142 ft
Czechia
Cauffy Posted at 8-4 06:53
listen to AJ he knows...
Don't discharge your battery's to a level that could damage the cells, these are lipo battery's and discharging them to 10% could shorten there life considerably. I to have had many drones and always land with at least 20% left in the battery and if im not going to use them for a few days i charge them to 50% and take them off the charger and store them safely. either the morning or the night before im due to fly i charge them back up to 100%. And then repeat this process as i see fit.
Actually there's no evidence that "discharging to 10% could shorten life considerably", cell voltage level is important and it looks like safety cut-off is set on a safe side. There shouldn't be much difference in landing at 30%, 20% or 10%, just avoid forced (low voltage) landing and do not override it with stick input for long time. And of course do not store batteries discharged, watch the temperatures ect.
BTW I see the YX multi charge hub on internet, that should have full charging mode and storage charging mode, that I was suggesting to DJI as a best option for battery maintenance.
