Lops
Flight distance : 747772 ft
M4cr0s Posted at 8-8 10:14
Dude, I don't think you quite understand what this technology is.
As far as I understand it, it is basically a receiver that detects nearby aircraft with transmitters that send on a specific frequency. It's not that much different from an old FM radio tuned to a specific channel, albeit this is of course digital. If some signal is received it will warn you if an aircraft is close. If there was a hacking risk, wouldn't aircraft that have both transmitters and receivers with this tech be at much more risk? ;)
I do understand the technology. But imagine there is an airsense warning about an aircraft having a speed, position and direction and the operator would decide not to fly away but to approach the incoming aircraft , what then? The receiver built into the drone is getting all necessary information. That means airsense is a system relating the drone to another aircraft with respect to position and movement. That is already enough to pose a security risk. For this a transmitter is not needed at all. In the worst case a software hack would enable the system to approach a certain target autonomously. From that point of view I do wonder why airsense is allowed in usa...
