Cetacean
Flight distance : 2528264 ft
fans9d8f6b0f Posted at 8-21 20:25
Umm, yeah, of course, it forced me to go elsewhere and land, manually.
The point of my post is to investigate if others have observed this behavior, if there's perhaps some setting needs be adjusted to fix this, and maybe even alert DJI to yet another possible software/firmware update fix.
Aloha fans9d8,
Aside from Geebax's very appropriate response, you might try using masking tape to tape paper towel to the bottom right and bottom left corners of your container lid (but in such a way that it does not blow up and in the way). Your Mavic Air 2 is a Porsche compared to your Spark (a Fiat). Big difference!
This exercise will show you the effect of shade and color (or lack of it) on your bird's sensors and which bird has the most sensitive sensors.
Hope this helps!
Aloha and Drone On! |
