Corvidae
Hello, I have a big problem after installing the FW 340. I am new here in this forum, coming from germany, and I will try to explain it in english so good as I can. (Sorry for my bad english).
Before updating to the new 340 - with 250 - the drone settings was really good and the smoothness in flight was great. Smooth turns in Tripodmode and Normalmode, with the new Gimbal settings. Everything works fine. The Obstacle avoidance in Tripod works also great. I have attached a picture of my problem, I hope you can see whats going on. I think, that the drone is spinning while turning in FW 340. It seems to be like a spinning in the movement of a turn. Trying to adjust the Gimbal setting in the 340 going to hell. Nothing worked. When I fly a turn to the left, the joysticks are in the positions, you seen on the picture, with FW250 is normal and smooth. With FW340 it spins around its axle? while turning, and at the end of the turn the spin is nearly complete 360 degrees. Further in the 340 I cannot adjust in Tripod the first APAS setting, its grey. Only the BRAKE or NOTHING mode. In 250 the drone is hovering over an obstacle and smooth fly over it.
I dont know how to solve the problem. Yesterday I had the next problem. I wanted to flying outdoor, have a great spot, start the Controller, start the App Dji fly, and the drone. Starting - the drone hovering, and I try to make a video. But nothing happens. The video function isnt working. Only photomode. The screen of my smartphone "flickering"? after I tap on the videobutton. after that, it turns grey, blackand white, then go back to normal screen. I landed it, drive home and refresh the firmware in the Assistant on my PC for both. Deinstall the DJI FLY App on my phone, and reinstalled it. Nothing worked.
Then I tried update to the 340 - and there is the videofunction working fine. But the same flight problem. And a nervous hovering in place. Like a rabbit. left, right. left right....and so on. Turning the stick forward, the drone starts forward, in the next moment its braking, after this its fly again. Thats only with 340 FW. So I`ll try to downgrade to 250 again. All seems to be fine, but after startscreen I have to camera working. And "Gimbal setting not compatible"- Message. WTF its going on with this ?
Why this is so complicated with this FW 340 update ? I dont wan`t to use the new setting, I want to get the old "good" 250 FW again, for smooth flying and for cinematic shots. I knew, that I am not alone with those problems. My SD Cards working fine, that I have checked.
I hope anybody find a solution or give a Hint for my problems. Thank you so far.
(Wenn Deutsche hier sind, könnt ihr gerne auch in Deutsch antworten :-) ) |
