MSD17
My understanding is that a "charge cycle" is based on the application of charging AND discharging a battery. For example...charge to 100% (base), discharge to 50%, recharging and discharging the same amount would equate to a single charge cycle.
Math:
100% base
- 50% discharge
= 50% REMAINING battery charge
+ 50% top-off charge #1 (1/2 cycle...battery is now at 100%)
- 50% discharge
+ 50% top-off charge #2 (1/2 cycle...battery is now at 100% again)
Both 50% top-off charges equates to 1 charge cycle
I could be wrong, but that's what I take from the term.
Basically, I look at it as the process of arriving at 100%. So another example would be... If I charge to 100% (base), discharge to 20%, then recharge to 100%...at this point I've only added 80% to the previous 20% discharge state so it's not considered a cycle. However, as soon the battery sees the remaining 20% in a future charge session it marks it a single charge. Hopefully that makes sense, but again...I could be wrong.
The reason I believe my theory could be correct is because the "Times Charge" on the pilot app is never the same as the number of manually documented times I've charged the battery. |
