dodger_rog
Ishka Posted at 8-24 04:40
Yes, if the camera data needs to be calibrated and updated to get accurate results, I would want to know how to do that. Is there a database online of what those values should actually be? or it is more of a research from trial and error?
Here are the results from a cross grid project, 60 degree shots with the same settings I had before...
Hi ishka,
To get your camera settings, you'll first need to use an exif reader online. I find this one really good:
http://exif.regex.info/exif.cgi
Upload ine of your images to this, doesn't matter which one.
Look for the values under:
Calibrated Focal length
Calibrated x
Calibrated y; and
Dewarp data (has a date and then 9 values, the last 5 are what you want). The last 5 values are the R1, R2, T1, T2 and R3 in order.
When you load a Project in Pix4D, where it has the camera there should be an Edit... button on the righthand side. Click this and then click New under the camera type.
On the lefthand side (think this is the "image" rather than "pixels" enter the calibrated focal length, x and y in the boxes and then enter the R1 etc values in the boxes below.
Rename the camera and save. Set this camera as default.
I'm not sure about any other drone models, we only fly the P4RTK sorry.
Any issues, let me know. I'm on the road for a couple of days but will answer when I can.
R |
