SkyBluP
Flight distance : 49518 ft
Nearly all the video I record with my phantom 4 pro+ 2.0 comes out with jello / is wobbly. I have searched this problem and see that some others have had the same problem and have tried various things to fix it but no luck.
I have tried:
compass calibration,
imu calibration,
changing props incase the props were not balanced,
turning off mechanical shutter,
resetting gimbal settings,
recording video at 4k60, 1080p60 and 1080p30
i also tried the gimbal calibration 3 times but everytime i try to do that it gets stuck at 50%. i have let it sit for around 15 minutes but it never goes past 50% so then i have to turn off the drone and the controller.
Some people said the problem is high shutter speed and ND filters can help, i think this may be true though i dont have nd filters but in one of my tests i tried to get shutter speed as slow as possible and the video wobble did stop. I have a video on youtube i uploaded that shows this, if you want i can link to video? In the video i am flying in the evening when light is low so shutter speed is already slow but the wobble is still there (not perhaps as bad as when there is alot of light) then in middle of the video i change ISO from 200 to 100 and the phantom then slows down the shutter to let more light in and at this time you can see the wobble stop instantly!
I have had this problem since i bought the phantom 4 pro but at start i blamed myself thinking, 'perhaps i am not flying smooth enough', or 'perhaps it happens because there is wind' but this happens when there is zero wind. and you notice it the most when flying slow or sitting still. The drone has never been crashed or landed hard etc.
