JJB*
Flight distance : 12225059 ft
BudWalker Posted at 8-26 07:02
The incident was caused by the loss of the left front prop. It either partially broke or completely detached.
The loss of left front propulsion can be seen here
Hi BudWalker,
Had a look too at this unfortunately flight.
Before this MP2 started to spin down, the left front motor almost stopped for short moment, well the RPM values from 5641 to 122 to 7070 again, see the data in my chart.
In the eventlog at this moment > CRAFT CTRL FAILED!!!
Then for 8 seconds 'normal' rpm values, than the spinning started and approx 5 seconds later high rpm values for this motor.
Uh, i would think loosing a prop/motor will cause the spin but in this flight the spin started before loosing a prop.
So i am little confused, did this drone lost a prop or ?
Before this a large mismatch in the compass data, guess due to the sudden yaw at shortly 122 rpm.
cheers
JJB
