CemAygun
Philippines
Fishycomics Posted at 9-13 05:18
Well DJI got nothing to talk about and site online info got more to say then gopro. some one from Ausie made this up, we're world wide so that means $400.00 usc. you can clearly see the photoshopping of it I took out where fround from Lol
[view_image]
This is made by someone who does not even know what a sensor is. The sensor size is the same, not "much bigger"; and the higher the resolution you have at a given (especially small) sensor size, the less quality you get. Depending on the sensor size, the lens and the aperture you can easily hit the diffraction limit, which means your alleged resolution is "fake". First few 4K GoPro's all had fake 4K; now they can do 4K unless you use the stabilization...
I really hate all this marketing BS. So many of the advertised functions are just useless gimmicks, yet everybody talks about them as if they were real, feeding the hype.
The only usable slow motion I have ever seen is on Osmo Pocket for instance. Even the $800 Mavic Air uses a pixel skipping algorithm to make use of the full FOV (the same way Osmo Action does) because it cannot read and process the full sensor at those frame rates. This results in an extremely aliased/jagged and utterly unusable output. Yet everybody claims these can do slow motion. With that quality, sorry but no, they can not! Pocket just gets an extremely cropped (1/4th) crop from the center instead, as it also is incapable of full sensor read. The FOV becomes a joke, but at least the output is perfectly usable.
Since the H9 is coming out in 2 days, probably we will get "unpaid", non-fan-boy reviews in a couple of weeks. I really need a proper action camera now (to be used where I cannot dare use the Pocket) so fingers crossed |
