George210477
Flight distance : 2676129 ft
Romania
Hello DJI,
You have a BUG in last firmware!
Problem seen:
If the drone starts in Tripod Mode, the Avoidance remains able to be checked, even if you made for Tripod available only Brake mode for obstacles.
(If you ask me, is stupid not to have also avoidance of obstacles in Tripod, as in Normal, but only Brake, but is your decision...)
As the button for Side Avoidance can be checked, but is working only as Brake...just decide: remove Avoidance button in Tripod mode or make Avoidance work in Tripod mode...
Another problem seen:
In HDR mode, the colors are waaaaay off the IPS standard...the hdr videos completely sucks if outside is sunlight...so maybe you will make a little adjustment in algorithm...Usualy I use D-Cine, but sometimes HDR is needed and takes time to recalibrate all colors. The drone does not have enough power to compile a manual adjustment like as Pro models? You will not loose market for Pro as the sensor from MA2 is half that Pro2...(also I must say that my Huawei P30 Pro have better quality than your sensor...)
In TRIPOD mode the joysticks are still very sensitive...is TRIPOD...make them 20% softer! Because the rotation is adjustable, but the speed still needs a very sensitive hand...maybe put a configuration for this mode in order to adjust everyone as it is comfortable ????
In 4K Zoom, at 2x Zoom, sometimes is losing the focus, when is 24fps and rotating...please fix it !
All these are software issues....we believe that you will act FAST to correct them.
Best reg.
