P3PRO Battery 1st Led Blinking NOT CHARGING
2083 11 2020-9-6
ChamalSB
Flight distance : 312352 ft
Sri Lanka
(i have 4 batteries tried to make good batteries from good cells)So,
i disassembled my one battery for check cell voltages. but not changed cells. (this battery worked before disassembly)
now it's not charging.
1st led flashing three times red is stable (not flashing) that time
after turns off two lights then REPEAT. how to solve
2020-9-6
ChamalSB
Sri Lanka
Sorry for sound this is the video of battery situation
2020-9-6
JetSam
Flight distance : 2521900 ft
PLUG the battery in the charger , and turn On The battery , maybe it ll charge it baterry ON
2020-9-6
ChamalSB
Sri Lanka
JetSam Posted at 9-6 03:55
thanks for reply tried it not working
2020-9-6
Smashey1
Flight distance : 160650 ft
In Hibernation mode? *** Sorry, this is for the phantom 4 battery but may work for you??***
So according to more experienced forum members try this - in this order.
1. If you've you just been trying it, plugging in the charger or turning the battery on, set it aside and leave it doing nothing for a few hours
2. when its rested, with the battery disconnected turn it on (short press followed by press and hold). Don't worry about LED indications at this stage.
3. set the battery aside for 5 minutes
4. Without doing anything else connect the charger (Plugged in and powered) into the battery and wait
5. it could take several hours - up to 24 for the battery to wake and start charging properly.
Good luck
2020-9-6
DJI Stephen
Super Moderator
Hello there ChamalSB. I am sorry for the trouble this has caused and thank you for reaching out. DJI does not recommended for you to dissemble your DJI Phantom 3 Pro's intelligent Flight Battery for safety purposes. Since this issue is happening DJI do not recommended for you to use the said batter to avoid any unwanted incidents when flying your DJI drone. Thank you.
2020-9-6
ChamalSB
Sri Lanka
Smashey1 Posted at 9-6 05:25
not working same thing
2020-9-8
Smashey1
ChamalSB Posted at 9-8 00:45
I’m sorry that hasn’t worked for you.
Perhaps other Phantom 3 owners might have more suggestions otherwise you may need to replace that battery
I thought it might be an over temperature alarm but it's LED 1 that's blinking so no clues from the manual.
2020-9-8
Mark The Droner
Flight distance : 2917 ft
I once acquired a battery that behaved just like that.   I tried every trick in the book.  It never did charge.  I eventually retired it.  Sorry.
Good luck.
2020-9-10
cheddar-man
Flight distance : 44062 ft
When I plug a battery into the charger after a flight LED1 flashes for "too hot". This obviously doesn't apply here as it's not hot!
I suspect you have damaged some of the "intelligent" circuitry while dismantling the thing.
Why did you need to check the cell voltage in the first place?
Which reminds me, must check my batteries, havent flown for a couple of weeks!  NEVER leave batteries for longer withour checking/topping up.
2020-9-10
Mark The Droner
cheddar-man Posted at 9-10 08:30
There is no such thing as "LED1 flashes for "too hot"".  It's LED4 that flashes for too hot.  Smashey's post #9 is accurate above.  My experience is when LED1 flashes 3x like that and then turns off, it's indicating that the battery voltage is extremely low and there is a good chance the battery is not salvageable.
2020-9-11
cheddar-man
Oh bother, got my numbers around the wrong way! Must remember to re program my brain!!
2020-9-11
