Just for statistics: my first quad, P3A + Nvidia Shield, Android DJI Pilot 1.1.0, FW 1.2.7 (no appreciable difference wrt 1.1.9), no video lag, easy FPV, in average a disconnection every 15 min, fast recover with a click, perfect video link up to 1.5 km (not tried farther).
Fast compilation at PAL 25fps, to be improved with ND filters (thanks PhantomFilter, just arrived!):
I first thought oh this is laggy and i thought this must be low FPS material and then i saw that you wrote 25fps. Its interesting how much difference 30fps will give you. Im in a PAL country but in times of digital filming i dont see a reason why to use 25fps, it just look not so smooth during camera tilting. I think it is only important when you want to create a PAL DVD for PAL DVD player but even in this case im not sure if modern DVD players can also play NTSC. So i guess its only from importance when you plan to broadcast your stuff in TV : p
Daninho Posted at 2015-6-23 20:49
I first thought oh this is laggy and i thought this must be low FPS material and than i saw that you ...
I hope ND filters and 1/50 sec exposure will solve the matter, just got ND filters yesterday.
The few times I was lucky to sell to TV, they were already scared by the difference between 24 and 25 fps...
Daninho Posted at 2015-6-23 22:39
yes but ND filters wont change the slow frame rate. They only give motion blur. I use 30 fps all t ...
Here a similar compilation with ND16 gel filter by PhantomFilters, exp = 1/50 sec, PAL 25 fps 1080p, converted to 780p 30 fps for 60Hz pc screens: the filter works very well.
