jasks
Flight distance : 113012 ft
I am having the same problem. I can't update to the new firmware to fix the incompatible firmware 30224 error.
I also have an "incompatible firmware error 30224" on my Mini 2, hence the need to update the firmware. The drone can't be flown at the moment. Susan had provided me with a beta firmware update for the Mini 2 to fix the incompatible firmware issue but I can't seem to update my Mini 2. Every-time I update, it will get stuck at 47% and the drone will disconnect from the RC and the firmware update will fail. Every now and then (1 out of 20 times), it will get up to 70% but then fails at 70% and again the drone disconnects from the RC and the update installation fails. The DJI saying it needs to connect to the aircraft.
I've updated the fly app on the mobile (Samsung S10+), swapped different batteries, formatted the SD on the drone, tried the dji assistant 2 (can't connect to drone) but still no working. Unfortunately, I don't have another device to use to try to update it.
I am running into multiple problems Any suggestions anyone? |
