Scott108
Flight distance : 314419 ft
Same here -- Logs sent to Airdata from 1.1.8 and 1.1.9 (iOS) have no temperature data. Minimum and Maximum are both reported as 0C or 32F. Also, the "Initial Capacity" is reported as 0mAh. These all reported correctly in 1.1.6.
Not clear to me whether it is the App not logging correctly, or maybe a change in format that Airdata needs to accommodate when reading the files. But I want it back! :-)
And this isn't limited to the Mavic Air 2.... I have seen the same issue reported with the Mavic Mini, so it is a more general problem with 1.1.8 / 1.1.9, for both MA2 and Mini, with both iOS and Android builds.
