flyflyawayhome
Thanks for all the tips and suggestions.
Planned a mission in Mission Hub that has 7 waypoints and stop at each corner of a rectangle, including two midpoints on the long side and a final waypoint at the starting point to "close the box".
Went out and attempted to fly it. It loaded and then complained that some waypoints are too close together.
I ended up deleting the last 4 way points, leaving 3 along one side of the rectangle with about 400 ft between the middle point and each end point. See image below.
So, question
1 what is the minimum distance between two waypoints?
2 Was the problem that WP 1 and WP 7 were at the same location?
Or was it that the short side of the rectangle is ~100 ft?
3 Is there a list of things NOT to do when defining a mission? I am unable to find such a list.
I want to figure out how to reliably create these missions so I can go out on a gig and have zero issues crop up.
I have yet to talk in detail with the client about their needs, so I am not sure where else I may run into an unforeseen error message.
Thank you for any ideas you may have and for your time in reading and replying.
