SimplePanda
Flight distance : 1719062 ft
Gimbals don't remove jello, they remove movement.
Take the vibration dampeners off your Inspire 1 and your footage (even with the gimbal) will have jello. Vibration will happily resonate through the gimbal motors just like any other part of the airframe. Physics is what it is.
Long story short is if you have jello on a stock Inspire 1 you have a major problem with your airframe. Any vibration that will move through the Inspire 1's isolated gimbal mount is high enough that it will potentially cause issues with your flight controller and this, ultimately, means your aircraft is at risk.
Reducing shutter speed with an ND filter is just a band-aid solution that masks the actual problem: excess vibration. You "need" an ND filter to slow shutter speeds if you can't isolate vibration but it's very much a hack to workaround the actual problem.
