New Smart Controller Firmware Released (22/09/2020)
12345Next >
25476 190 2020-9-21
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2020.09.22
  • Smart Controller Firmware: v01.00.0820
  • DJI GO 4 App: v4.3.36
  • DJI Pilot App: v1.8.0
  • DJI Fly App: V1.1.6
  • DJI Assistant 2: DJI Assistant 2 For Mavic v2.0.14
What’s New?
  • Added support for DJI Mavic Air 2.  Under Aircraft Management, Mavic Air 2 can now be added and managed.
Notes:
  • A Smart Controller with a firmware version of v01.00.04.75 or earlier must be updated using DJI Assistant 2. Download the latest DJI Assistant 2, and follow the steps in Firmware Update section in the DJI Smart Controller User Manual. Download DJI Assistant 2 at https://www.dji.com/cn/mavic-2/info#downloads
  • Contact DJI Support if the update fails several times.
2020-9-21
Henry7722
Taiwan
2020-9-21
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2020-9-22
FloridaNext
Flight distance : 62320 ft
Nice, but what about the faulty video feed at startup? Still not fixed?
2020-9-22
AEROKAMERA
Flight distance : 2289429 ft
Poland
What was fixed?
2020-9-22
Andy Uk
Flight distance : 3985676 ft
Does anybody know yet how this works with DJI Fly and whether the buttons and extra thumb wheel can be custom mapped.  For example it would be good to be able to use the 2nd thumb wheel to use the new zoom features on the Mavic Air 2 as well as being able to map custom functions to the 2 custom buttons (on the rear) and the 5 way controller.  My guess is this is going to need a DJI Fly Update to fully realise but it woud be great if this were the case now.
2020-9-22
LeeG
Flight distance : 169281 ft
THANK YOU MAVIC !
2020-9-22
FictitiousPerson
Flight distance : 303356 ft
LeeG Posted at 9-22 02:21
THANK YOU MAVIC !
Who’s Mavic ?
2020-9-22
Coojeebear
Flight distance : 572484 ft
Constant failing at 99% download. Insufficient space.
No maps, no images/video, formatted video cache, Is the update too big to fit on the Smart Controller?
Nightmare of an update! Everyone having problems.
2020-9-22
MauroT
Flight distance : 16041247 ft
I got stuck with the update at 99% and now it doesn't start anymore, I'll try again later
2020-9-22
Coojeebear
The update fails - as is normal for DJI then leaves it's partial update files in the controller, eventually running out of space.
2020-9-22
jmb63
Flight distance : 7009439 ft
Updated fine here!
As always with the Smart Controller, remove your sd card before updating, change your screen time out/sleep to a much higher setting (at least 10 minutes temporarily), and should just update using DJI assistant !
2020-9-22
jmb63
Coojeebear Posted at 9-22 02:42
No problems here...
2020-9-22
sergeant
Sweden
If you're running an older firmware, you'll need to update using the DJI Assistant 2 app instead, this is clearly stated in the release notes.
2020-9-22
Wolic
Flight distance : 130046 ft
Good News!
2020-9-22
MauroT
same problem, via wifi is 99% stuck, I tried to do a factory reset but it always stops at 99%. I try via dji assistant .
2020-9-22
Coojeebear
MauroT Posted at 9-22 04:55
Good luck, come back if you have no space. I have a partial fix.
2020-9-22
JJB*
Flight distance : 12225059 ft
Hi DJI,
When i buy one...is the FlyApp already installed??
As in the past only the GO app was installed.
cheers
JJB
2020-9-22
The Saint
Flight distance : 5902228 ft
awesome!
2020-9-22
KlooGee
Flight distance : 16783757 ft
JJB* Posted at 9-22 05:19
Hi DJI,
The Fly app is installed as part of the new firmware.
2020-9-22
JJB*
KlooGee Posted at 9-22 06:03
Thanks for your answer
cheers
JJB
2020-9-22
MauroT
fine via dji assistant 2.
2020-9-22
Chill Pill
Flight distance : 44731 ft
Installed flawlessly here with Dji Assistant, although took a couple of hours with slow internet access. Didn't remove memory card so that is a myth. It was on 99% for a while with controller rebooting a few times in the process but got there in the end. Have test flown both Mavic Air 2 and Mavic Pro 2 using the controller with no issues so far.
2020-9-22
LeeG
Anyone get this to install yet? For me this failed twice via DJI Assistant, and later also when SC tries to install itself. Getting insufficient memory, and I have no media pictures on the smart controller. What a pickle!
2020-9-22
KDP +
Flight distance : 947930 ft
Always risky.... Everything working well now with my M2P.... Shall I update or not....?
2020-9-22
A J
Flight distance : 13864580 ft
At last
2020-9-22
AEROKAMERA
Poland
Use DJI Assistant 2
2020-9-22
Oracle Miata
Flight distance : 3759829 ft
LeeG Posted at 9-22 07:07
Same here, via either format.  I also have nothing on my SC.
2020-9-22
AEROKAMERA
Poland
Still chinese text in DJI LAB menu
2020-9-22
GoFly Drone
Flight distance : 547438 ft
any ideas why Dji Assisant 2 wont connect my smart controller , everytime i plug controller into Macbook it just says slow charging the arrows for communicating are showing on controller screen but nothing happens on assisant , tried various diff cables etc , just stuck on 99 % download for a hour (so far) doing it on wifi ....bloody thing lol
2020-9-22
raven swe
Flight distance : 517936 ft
Sweden
updated fine here first go
2020-9-22
BobWinNV
Flight distance : 284209 ft
Hi DJI,
After I did the update the Fly app was installed on the Smart Controller but it is version 1.1.6
2020-9-22
JJB*
BobWinNV Posted at 9-22 10:53
Thanks for the update Bob,
if i have some money somewhere i will buy one.
cheers
JJB
2020-9-22
djiuser_ncJhMemYv0hi
My attempt to update the smart controller failed twice using DJI assistant ?
2020-9-22
The Saint
I could have sworn I had to perform either an aircraft firmware update or a battery update AFTER my first MA2 connection with the scm.  not seeing it for any other battery tho.
2020-9-22
Planner68
Flight distance : 1194662 ft
Pretty cool.  Now I need the Mavic Air 2.
2020-9-22
AntDX316
Flight distance : 3394731 ft
I said if they release an update for the Smart Controller I would get a Mavic Air 2 but then I would have to get batteries and a case.  I already have an M2P and M2Z so I will just use them instead.
2020-9-22
AntDX316
P4PV2.0 support?  Who has tried?  I use Pix4D so I just use it w/ the iPad.
2020-9-22
fansaccfc0b8
Flight distance : 136322 ft
Mine too. How did you get it to update. It’s horrible
2020-9-22
fansaccfc0b8
djiuser_ncJhMemYv0hi Posted at 9-22 11:33
Same here.
2020-9-22
12345Next >
