Gerth E
Sweden
K6CCC Posted at 9-28 21:45
No, your video does not show the behavior that mine does. The closest that I can come to what you are seeing is if the hub is not plugged into power - but even that is not quite right.
As a test, do you have some other device that you can charge from the adapter and cable - such as a phone, headset, GPS, etc.? Does that work? And confirm that same adapter and cable when plugged into the drone will successfully charge a battery? I am testing something, but it will be morning before I have a result.
Hi - Thanks for a fast reply
The USB charger and cable used do charge the battery ok if I plugg it directly into the drone , have charged all my three batteries that way. So that is tested, and all batteeries have been fully charge at least once.
Charging the batteri in the drone was made from the same wall socket so that's not a power issue.
Will try to charge another device - but I expect it to be successful.
Have been seeing in one of the Youtube videos that a "Quick charge" cable is needed - I have tried both of the supplied cables and the behavior is the same.
Is there any way to distinguish a "quick charge" cable from another regular ? |
