KREMi
Poland
Giammi Posted at 10-1 22:52
I perfectly know about the Mbps but it's too small and I can't check it while flying. A message in the middle of the OSD would be way better.
BTW, I'm running crossfire with diversity RX, so failsafe is not an issue.
I do fly analog even now, but honestly Switching drone by drone to digital. I do wait for sharkbyte tho
Your setup (looking @power and antenas) is long range, so I think You push this system to it limits.
Only case when I won't see bitrate/pixelation degradation is really close to max range flights and then drone get into some strong outside interference (power lines, telekom tower, etc) - it can kill videotransmission pretty quick. but then going higher altitude usually fix it.
I would suggest a small GPS + RTH setup in FC, that in this case flip a switch should save You
and maybe if there is also a drop in radio signal at crossfire (which should happen, not to low value, but at last it should get lower), so audio alert in radio is an option? I got frsky, so RSSI low alerts for me, crossie is even better with LQ |
