battery quarterly maintenance, draining fully
990 14 2020-10-1
ChrisLoon
in each battery box the documentation mandates quarterly draining, fully, subsequently, recharged back to full
proprietary gold contacts can only attach to the aircraft
aircraft turns off the battery involuntarily before emptied fully
and, such draining, using the aircraft as the load, unnecessarily bites out life from electronic longevity
battery warranty is half year, and forum longevity claims about 100 cycles hot versus 200 cycles cold
it is hard to understand 200 recharges capability, done the right way, i.e.,  recharging cold battery, because in flight it gets really hot
in other words hot eats battery life, so 200 recharges is a bit exaggerated, doshould you ignore fully draining quarterlies?ne the correct way
the theme is this. do you really have to fully drain quarterlies?  smarter to re-enter hibernation? hybernate status gives zero indication when polled
entering hibernation status will relieve you from quarterlies draining fully, however, is there going to be another parasitic degradation biting longevity while in sustained hibernate status?
2020-10-1
Ex Machina
Flight distance : 1806362 ft
First time I've ever heard of a quarterly draining recommendation. Is this for people who rarely fly their birds or something?
2020-10-1
K6CCC
Flight distance : 651683 ft
As a general rule of thumb draining any rechargable battery to absolute zero is a really good way to kill them.  I find that recommendation odd at least...
2020-10-1
Suren
Flight distance : 13425892 ft
New Zealand
if you are not going to be using the battery for a long time and going to store it, it is recommended that you charge it fully at least once every quarter. you cannot store a battery with no charge for very long periods the cells will die off.
2020-10-1
DJI Stephen
Hello there ChrisLoon. Thank you for reaching out and for these information you have shared. The DJI intelligent flight battery has an Auto-Discharging function to prevent the said battery for swelling, the battery automatically discharges to 96% of the battery level when it is idle for one day and automatically discharges to 60% of the battery level when it is idle for 5 days. It is normal to feel moderate heat being emitted from the battery during the discharging process. For additional reference I will post a list of the intelligent flight battery safety guidelines. Thank you.
2020-10-1
A J
Flight distance : 13877205 ft
I have no idea what instructions you are referring to but in the official DJI manual for the Mavic Air 2 they recommend fully recharging the battery to 100% at least once every three months in order to maintain the long-term health of the battery. They also define the discharge level as being less than 30%. There is absolutely no instruction in any DJI manual telling you to totally discharge the battery to 0% on the Mavic Air/2. DJI use to advise this on older drones such as the Inspire 1 but not now.
2020-10-4
ChrisLoon
A J Posted at 10-4 13:52
[view_image]
Says discharge to 30% and lower without bounds
And again it says discharge maintenance to less than 30% again without bounds
2020-10-15
ChrisLoon
I bought a discharger that attaches and supplies USB charge output to recharge cellular phone at ceiling draw two ampere and discharge is slow until battery auto off's itself being exhausted unto protective lower set point internal.
Battery remains cool always, intelligent discharger active circuitry. But delayal to charge back up full will induce battery irreversible harm, so charge immediately after draining procedure.
2020-10-15
A J
ChrisLoon Posted at 10-15 09:35
If you actually interpret '30% or lower' as 0% then go ahead. lol
2020-10-15
ChrisLoon
DJI Stephen Posted at 10-1 22:47
[view_image]
Gosh, thought mavic air batteries take 10 days before self discharge to 2/3
And, the 1 day grace before 4% drain of 100% is something unknown to the original mavic air gamut era 2018 ending year
Recently, my 100% batteries in flight disappear altogether instantly, sometimes indicated by color red 0% announcing critically low battery casualty immediately landing protectively, and sometimed the red color 0% immediately flip flops back to green color 100%, yes, heart attack, and continues flight pristine.
Told dji about it, solution, upgrade asst2v1.2.4 into 1.2.5, refresh all batteries, success, then attempt conservative operational check, discovery, battery won't turn on, did 1.2.5 refresh battery kill it? Dji requests paired devices plus all batteries returned for forensics
2020-10-15
ChrisLoon
A J Posted at 10-15 09:55
A good metric to evaluate capacity degrade is to fly above in a large repeating circle checking drainage with respect to time. This 21 minutes will evidence either ruin or healthiness.   I fly around the big church steeple, central union church, lots of parrots campaign in the hundreds but refuse to engage, they sensate wireless giga hertz
2020-10-22
A J
ChrisLoon Posted at 10-22 16:45
Yeah, 30% or lower
2020-10-22
ChrisLoon
not really the facility somehow tweaks alarm at 35% dunno why else is 30% alarming trip point so gotta land upon notice, of course 35% is lowered landing with propulsion.
2020-10-23
Geebax
ChrisLoon Posted at 10-23 11:10
English is not your first language, is it?
2020-10-23
ChrisLoon
semantics is calling your comprehension;  the 35% occurs airborne with home icon displaying additional allowable flight time before return, of course charge depletion below 30% will occur. Makes you wonder why that circumscribed "H" on the charge flight  display is calculated incorrectly.
2020-10-24
