frankymusik
Flight distance : 27841053 ft
djiuser_yXev2MQIC3Ff Posted at 2-22 15:53
I just got my Mavic Air 2 with Smart Controller and noticed the issue with the compass 90 deg clockwise from the orientation of the controller. So with the controller pointed North the direction pointer in the DJI Fly app is pointing East. Smart Controller Firmware version in 1.00.0880 and DJI Fly app version is 1.2.2. I then downloaded and installed DJI Fly app version 1.2.4 and the problem still exists. It gets very confusing when trying to fly by map, hopefully, it gets fixed soon. Compass calibrations do not resolve the issue.[view_image]
It's really a shame that DJI can't solve this problem ...
... they promised over and over again ...
I asked the service directly months ago, but unfortunately it doesn't work at all; i only hear promises!
I now own a brand new MA2 Fly More Combo including the SC.
Unfortunately, the problem mentioned above is the same as with my "old" SC, which I had returned in the meantime ...
But, may I add a question that is a bit "off topic"?
If you had switched on the SC for a few minutes (after it was fully charged, i.e. 100% display in the battery symbol) until this battery display may have dropped to 97 ... 99%:
Switch off the SC and connect it to the supplied power supply unit with the (special) supplied USB cable ...
How long does it take on your SC until the charge indicator (the four rapidly flashing white LEDs) go out again?
With the original charge level of 97 to 99%, it should only take a few minutes, right?
For me it takes about 1 hour, so I think that something could be defective ...
Could you answer the question, please?
Thanks in advance!
Frank
