AntDX316
Flight distance : 3394731 ft
Need the Ronin-S camera upper motor section to be connected to some DJI Tripod battery mount. Right now, we have to use the full DJI Ronin-S setup then attach that on top of a tripod. This makes it unstable where it moves from being so tall. If there is a DJI Tripod battery mount that is video grade ready, or you use an adapter to use the mount as a hotshoe that is wired further away the Ronin-S stick battery, it would be a lot better. The purpose is so I can look at multiple things like a drone with just gimbal control sticks than to loosen the tripod screws to move the camera to the desired direction then tighten it down on each of the 3-axis. It would be a lot more rapid and better to be able to just use the Ronin-S upper section to do all the movements.
When you want to move the camera say 0.125° in a direction or you want 2 more degrees or want to go 45° or even 270°, you have to got through the Whole process. When you have force mobile and active track, it would make it an option production equipment. It can get tedious because your roll axis could be a bit off. This eliminates All of those issues. |
