Hi to all, is the first time i write here and i wanna ask you one thinghs.
How i export my vidio on youtube without he convert and make artifacts on that?.
I use Movie studio platinum and i need put online in 4k, the last vidio put online and reconverted from youtube it make horrible conversion.
isee but in movie studio platinum i try chose different codec but after put on youtube it convert and see always not clean in some part of video.
I will reup the vidio and let you see what i mean.
Only template aviable for 4k is sony xavc an can't change a lot of that.
Thank's
I would start by downloading it from you tube and playing it locally to see if it's got those artifacts. It's likely that the you tube player is downsampling the video on the fly due to bottlenecks in the internet. Just a hunch.
After uploading the Video it takes a few minutes unless it's available in 4k.
If have waited long enough, please post a link to your video, so we can help identify the issue,
@lamiapostaperof:
[ITA]questa cosa è stata già discussa nel forum un po' di volte, a quanto pare il problema è nella banda riservata alla scrittura dei dati sulla microsd. Poca banda = encoder costretto a creare artifatti. Succede sostanzialmente sui prati, proprio come nel tuo video. Al momento non paiono esserci soluzioni. Purtroppo.
Doom9 è un ottimo posto dove poter chiedere!
[ENG]already discussed on the forum some times, afaik the problem is in the bandwitdth of card r/w. Low bandwidth = encoder forced to create artifacts. It happens on weed fields, like in your videos. At the moment there isn't any solution. Unfortunately.
Doom9 is a great place to ask!
@lamiapostaperof: [ITA] come wiregrassbulldo ha scritto da un occhio qui, probabilmente la tua configurazione è buona ma non abbastanza ottimizzata per YT. Inoltre da un occhio qui è una buona infarinatura.
First, Thank you showing us that nice region of Italy, i will do a stop next time i'm driving to Lago di Garda, i love Italy
Regarding your Film, i haven't watched the full video, but have seen artifacts when you do the turn at 0:40
it seams that Youtube doesn't like 4k and high density object like grass or woods.
I did a Test Video when i got my Bird and have the same artifacts, post processing was with Final Cut Pro
