JEZ2
Flight distance : 336204 ft
To clarify on the home point, the Air 2 allows you to set a new home point to 1) The drone's location, 2) the controller location, or 3) a point on the map.
Without GPS, you can still do #1, you can't do #2, and if you have cached the maps (or connected to wifi or hostpot) you can do #3.
Otherwise, you have good answers in terms of limitations (have to pre-cache maps, can't authorize if need be without cell). One more is the location information of the controller compared to the drone has the potential to be less accurate, although even the wifi only ipads still approximate location from wifi signals and such. |
