Ray-CubeAce
No problem.
I'm not sure if I can agree with the others here that is normal behavior or not.
I do agree the Osmo Pocket will amplify any vibration around it and it transfers across to the video but I've always had my Osmo Pocket set on a a firm, dense surface for this type of shot (like concrete or rock) or on a very heavy duty and vibration free tripod which sort of negates the Pocket's portability.
When I did my double take videos, any movement of the Osmo Pocket would have shown up where the background blended together and it didn't. But then gain, I was on a concrete floor using my heavy duty tripod.
I also know sometimes that using time-lapse leaves gaps you don't want between frames so is not an ideal solution for some types of shots. Then again even a heavy duty tripod does not help if the ground it is on picks and transmits the movement through its legs.
I know when using a different camera that leaving any stabilisation on (lens or body) makes the frame jump around and has to be turned off for that type of shot Gimbals on the other hand should only respond to counteract movement but are hyper sensitive to vibration as well as movement in the conventional sense.
If you were on a wooden floor or using a wooden or glass bit of furniture to support the Osmo Pocket , that could also be part of the problem.
Ray. |
