Mapping H20T ??
11493 26 2020-10-18
Dre Drones
Flight distance : 234505 ft
Belgium
I know the P1 is announced, if I had this from the start I wouldn't have bought the H20T. However, is the H20T usable for mapping ?
Are there any alternatives that anyone on this forum is using ?
Thx,
André
2020-10-18
Hi André, the Zenmuse H20 Series was not designed specifically to meet the accuracy requirements for aerial surveying, but you can use the wide-angle camera to capture images in Mapping missions in the DJI Pilot App.
2020-10-19
Dre Drones
Belgium
DJI Mindy Posted at 10-19 01:20
Hi,
Thanks for the quick reply. Yesterday I was trying the features Mission planning 'Waypoints' and 'Live Recording' (for the first time). None of them works neither in GPS-mode nor in RTK-mode. The Pilot app just shuts down after a while.
Any suggstions ?
Gtz,
André
2020-10-19
nikolaospaschalisgmail.com
Flight distance : 3093517 ft
Greece
Matrice 300-dji terra -1000 photos
2020-10-23
NeoGreg12
Flight distance : 1198714 ft
Works pretty well, lots of overlap and set the zoom to 2x during entire mapping flight for additional details
900 Images
2020-10-26
Dre Drones
Belgium
Awesome, thx I will try it
2020-10-26
DerMudder
Not pretty, but fast. Created from only 12 pictures with the wide angle camera.
It is not something you present to a customer. However, it is something that an emergency manager is interested in to get an overview of a terrain / accident site / fire.
2020-11-12
MW_POE
Fly higher and use wide. Zoom requires custom setup and is tricky for mapping but less so at higher AGL. Try swapping height and width of image size, more consistent with mapping path and better results.
We have been unsuccessful with mapping below 80m. Due to custom cam setup, still in testing. Thermal also challenging at lower than 80m. We only use zoom for manual inspection. Also, during mapping only save what you need. We have seen delay in image save with multiple types causing gaps. We use wide or zoom and thermal only, not all 3 and never view.
2020-11-20
Craig_Tas
Flight distance : 2998255 ft
NeoGreg12 Posted at 10-26 05:23
[view_image]
I have the custom camera setup for the H20T (can't wait for the P1) what heights do you recommend and overlap to get the detail you have in this sample?
2020-12-16
SYC
Flight distance : 63114 ft
Someone from DJI Dealer in Shenzhen told me that SHARE UAV 102S professional mapping camera is perfect for aerial photogrammetry with M300 RTK.  It has 5 lens and uses oblique photogrammetry.  The web site is: http://www.shareuavtec.com
The Dealer also told me that Zenmuse H20 series is not specifically designed for high-precision aerial photogrammetry.
I am still trying to get more information from the Dealer.
2021-1-21
Craig_Tas
You can now pre-order the Zenmuse P1 camera, designed for mapping
2021-2-1
Dre Drones
Belgium
NeoGreg12 Posted at 2020-10-26 05:23
[view_image]
Hi did you use the Pilot. Can you program the flight and take pics with zoom 2 or 3 times?
2021-2-10
MMD
Flight distance : 106631 ft
Montenegro
I have demand to map some heat pipes. Is h20T good solution for it or should i chose XT2 or XTS? I also need to make orthophoto with RGB camera.
2021-2-12
Dre Drones
Belgium
Hi I tried some mapping with the H20T wide (as preset in the Pilot App) and this was the result in Px4D.
The street is as flat as ca be. Not so in the picture, can this be corrected without flying again ?
2021-2-18
mikes1
Flight distance : 1740699 ft
I have tried mapping using the H20T. I have yet to be able to tell the Pilot app that I only want to use the Zoom camera. I have unchecked the boxes in the camera settings but it always takes pictures with both cameras. The wide camera is absolutely unusable. It is a total waste of time. The Zoom camera has a much better sensor and could be used to map with. WHY does DJI not offer the ability to choose the Zoom camera when mapping? The wide and thermal camera is visible in the settings but not the Zoom. I have experimented with setting up a custom camera but have not had any luck. Has anyone attempted setting a custom camera that would match the Zoom? It would also help if the settings on the zoom would not default to 2x zoom. Why not 1x? It would be easier to match the sensor if trying to configure a custom camera. Luckily I did not buy the H20T to map with. When I purchased the M300 I knew the P1 and L1 would be available which helped me to make my buying decision but I guess this has to do more with marketing.
2021-3-7
NeoGreg12
Dre Drones Posted at 2-10 13:03
Yes I used pilot. There's no option to set the zoom but as long as you set it before the autonomous flight it should remember the setting. 2x seems to be best and make sure the speed isn't too high or you'll get some nasty motion blur on the zoomed images.
2021-6-4
NeoGreg12
Craig_Tas Posted at 2020-12-16 16:26
It was a little while ago but I think I was around 50m about the structure here. I used the roof for take-off so overlap ratios were calculated from roof level not ground.
I can't remember exactly but the overlap ratios were around 80% all over. Hope this helps!
2021-6-4
EDSC
Flight distance : 2791378 ft
nikolaospaschalisgmail.com Posted at 2020-10-23 13:15
[view_image][view_image]
What were these photos taken with?
2021-8-29
DJIPEGGY
Belgium
hi all, we have many issues with H20T mapping flight where zoom lens is used.WHat happens is that the zoom levels are changed during the flight. from X2 zoom it suddenly changes during the flight to X5. Absolutely crazy issue accross all pilots.
2021-9-30
VolantDrone
Flight distance : 354646 ft
[view_image]
NeoGreg12 …i just came across your response to this post. Are you saying you used images from the zoom camera to produce these models in terra? I am trying to think of alternatives if my partner is using our P1. Not sure if I’d be better off flying a phantom. Just curious
2021-12-30
Raw_B
Flight distance : 1494190 ft
What do you mean by the custom camera setup?
2021-12-30
Raw_B
Raw_B Posted at 12-30 17:59
Never mind, I get what you're saying, in the camera setting.... At first I thought you mean't like a customized H20T camera.
2021-12-30
C-R-O-N-O-S
Hello,
I can only speak for the H20 that I use for other things.
My experience is that absolutely ALL photos are NOT good for photogametry, because there is always a lens distortion correction included.
With my combination of M300 and Pilot App I cannot switch this off.
In addition, you have to do a rolling shutter correction.
It may be enough for "respectable" photogammetry, but I need evaluable and reliable results.
But I'm happy to be proven wrong!
2022-1-15
djiuser_9bIYGQ4G2BYN
[view_image]
which program did you use to make this picture
2022-8-31
djiuser_SdqV70yzMHwj
Was this done with the h20t?
2023-5-16
AR_AirPrecision
Flight distance : 2660509 ft
Belgium
C-R-O-N-O-S Posted at 2022-1-15 13:53
Hello,
And you need GCPs
2023-5-17
[view_image]
Was this taken with an h20t on the m300? Pretty great quality considering the sensor.
2023-7-6
