What is M.M in the camera settings area?
11622 25 2020-10-19
invictus
On the Mavic Air 2 there is an M.M value displayed next to the camera settings. What exactly is this and how is it used? Thanks!
M.M
M.M
2020-10-19
JJB*
Flight distance : 12225059 ft
Guess it stands for Manual Metering....
2020-10-19
Labroides
Flight distance : 9991457 ft
It's an indication of how much your manual settings differ from what the camera's meter shows.
2020-10-19
invictus
Thanks, I had a feeling that's what it was but couldn't find anything about it.
2020-10-19
DJI Stephen
Hello there invictus. Thank you for reaching out and for the inquiry. As JJB* posted on post #2 it is the Manual Metering if the DJI Fly application. It is the measurement of the exposure value when setting the ISO and shutter speed in manual settings. Minus ( - ) means it is under exposed and Plus ( + )  means it is overexposed. Thank you.
2020-10-19
Suren
Flight distance : 13425892 ft
New Zealand
It is a switch to make it a Mavic Mini ..............just kidding
2020-10-19
Montfrooij
Flight distance : 2560453 ft
Can you set it to -0.7 or so?
In auto mode (like EV compensation)?
2020-10-19
A J
Flight distance : 13838848 ft
Montfrooij Posted at 10-19 23:04
No mate - minus to plus 3 only
2020-10-20
Montfrooij
A J Posted at 10-20 00:09
Ok.
And you also have EV compenstation in the fly app?
2020-10-20
A J
Montfrooij Posted at 10-20 00:46
Ok.
Yep - EV comp is there
2020-10-20
Montfrooij
A J Posted at 10-20 01:39
So what does the M.M do then?
2020-10-20
A J
Montfrooij Posted at 10-20 02:06
With peanuts?
Manually touch the screen when in auto settings and the camera will shift the exposure to compensate for that precise point highlighted with a yellow circle. You can alter the EV manually then lock it in thus mixing auto settings with manual metering.
2020-10-20
Montfrooij
Hahahahahahaha
Those are the best.
OR OR OR
Wait for it
2020-10-20
A J
Montfrooij Posted at 10-20 02:16
Hahahahahahaha
Those are the best.
OR OR OR
& as Suren pointed out it turns your Mavic Air 2 into a Mavic Mini with kite mode
2020-10-20
Montfrooij
A J Posted at 10-20 02:11
With peanuts?
Can't find it anymore.
We sometimes mix a big bowl of the 3 kinds and have M&M fest.
2020-10-20
Montfrooij
A J Posted at 10-20 02:18
Yeah that was killer!
2020-10-20
A J
Montfrooij Posted at 10-20 02:24
Love it
2020-10-20
A J
2020-10-20
Montfrooij
Me too
2020-10-20
Rustic17
Flight distance : 2716936 ft
Funny....I've been flying with -0.7 in Auto in both Photo and Video modes.  And after a 12 day trip, I've realized that 0.0 is probably best.
2020-10-20
A J
Rustic17 Posted at 10-20 20:47
Thats -3.0 to + 3.0
2020-10-21
GCxCD
Flight distance : 119209 ft
So, when in auto mode, you can set and lock the exposure but in manual mode you cant do it? It just tells you if you're over or underexposed but you can't change it? Other than adjusting your shutter speed and/or iso?
2021-7-2
Labroides
GCxCD Posted at 7-2 19:44
You have that mixed up.
In auto mode, the exposure isn't locked and the camera's metering will change the exposure to suit the scene and lighting conditions.
In Manual mode, you have set the exposure and it won't change unless you change the shutter speed or ISO.
2021-7-3
Friction
Hi --
I have the same question as the originator of this thread.  When I have the camera in "pro" mode and I adjust the ISO and the shutter speed, the MM value stays at -3.0 and it is grayed out.  After reading all the answers, I can't figure out what changes the MM.
Thanks in advance for any help.
2021-11-7
Rustic17
Friction Posted at 11-7 17:54
Hi --
When you get to -3.0 that's as far as the MM meter goes...gray probably means the setting you've selected is past the -3.0.
2021-11-7
Labroides
Hi --
That's telling you that your camera settings are 3 or more stops underexposed for the available light.
Adjust your camera settings to give proper exposure or take your camera outside in daylight where there is more light.
2021-11-8
