nfrancisco
If you're looking for a drone case that fits carry-on requirements, check out CasePro's Quadcopter Cases page: http://www.casesbysource.com/brand/casepro-drone-quadcopter-cases
All cases that are labeled "Carry On" meet carry-on size requirements. The ones that do not will have to be checked but don't worry! CasePro's hard cases are heavy-duty enough to protect your drones no matter how roughly they are handled at the airport. The high-density foam interior, which is designed specifically to hold Phantom 3's, will cradle your drone for snug and durable protection. You won't even need to remove the propellers!
I work for CasePro, and I would definitely recommend trying the P3 case with our new RecoCell foam: http://www.casesbysource.com/pro ... d-case-cpe-phan3-co
RecoCell foam adds more cushioning and protection. Like memory foam, RecoCell foam shapes itself around your Phantom 3, creating an ultra-snug fit without damaging the drone at all. You can even customize CasePro's foam interiors to make sure you have a cavity for all your accessories. Just click the orange "Add Custom Foam" button on the individual case pages and use our online tool to build your personalized foam insert. |
