Zbip57
Guorium Posted at 12-4 07:09
I think you have the answer already. Your theory is not working 100% of the time. It is not happening to everyone... Many including me store mini in the combo case and have no ESC beeps. Props are made of thermal plastic with shape memory to it. You bend it a little it comes back to original shape. I find it very hard to believe light pressure cause permanent deformation. That guy with a 25 day old mini just showed his indoor hover data disproving your theory and you just ignored it. I really think it is some other things people do unknowingly to the props to flatten them. Many pilots can be very ignorant and careless to their drone making accurate diagnostics a very hard task. Just look at how many crashes we have reported all over the net. I do appreciate your effort for investigating this issue though. We need more like you questioning design flaws.
"That guy with a 25 day old mini just showed his indoor hover data disproving your theory and you just ignored it."
Are you talking about "that guy" who I replied to several times with helpful suggestions, which he ignored?
I suggested that he should do another hover test, since the 30sec data plot he shows is not long enough to draw any meaningful conclusions and thus neither proves or disproves anything. My own data plots show that it takes about 30 seconds for the Mini to settle into a stable hover.
I also suggested he should repeat the hover test with the drone rotated at each of four compass directions, as that might provide a clue as to whether his drone's motor speeds are being affected by any crosswinds. He didn't do that either.
"Many including me store mini in the combo case and have no ESC beeps."
Lucky you. All I can say is, that has not been my experience.
"I really think it is some other things people do unknowingly to the props to flatten them."
No doubt there are many worse things that can be done to damage propeller blades, but there is plenty of evidence that folding them together across the body of the Mini will bend the blades.
"I find it very hard to believe light pressure cause permanent deformation."
Let me ask you this. Have YOU ever done a hover test to document your motor speeds?
If you have never received a motor speed warning (or max power reached, or propeller speed warning) with a subsequent beeping ESC after landing, it likely means your prop blades are not (yet) sufficiently deformed to trigger the warning. But the hover test is still a worthwhile, accurate, and conclusively repeatable way to measure the current health of your propeller blades.
You mention "light pressure". If your propeller blades can be folded together laterally across the body of the Mini using only "light pressure", it's a clear indication that your blades are already permanently deformed. Have you ever installed new blades on the rear motors of your Mini? When I did that on my own Mini it was immediately apparent that brand new rear blades cannot be folded together without forcing them to bend.
Again, it's not the bending alone that's the primary concern. The danger is that the blade tips are then also twisted, causing their angle of attack to flatten out or potentially even become negative.
Do a hover test, allowing the Mini to settle hands-free into a stable hover for at least two minutes, even better run it for five minutes. Do it in an area with no wind. If you think a crosswind might be affecting your results, repeat the test four times with the Mini facing in the four different compass directions. Save the dat flight log file, and using CsvView plot your Motor Speeds.
You may be convinced your propeller blades look perfectly fine and are working well, but plotting the actual motor speeds is the only way to know for certain.
"Your theory is not working 100% of the time."
If you can prove me wrong, using a test that anyone else can repeat to definitively verify the results for themselves, please do. Just because you personally have not (yet) experienced the same issue, is not proof that there is no issue. It's like saying I flew my drone on Thursday and experienced no problems, thus proving that Thursdays are the only safe day to fly.
