Malakai_UK
Flight distance : 536115 ft
I can see your comparison to photography here, sure capturing a photograph at less than 1/60th of a second creates a bit of blur unless you are using a tripod. This might sound counter intuitive but thats exactly what you want to happen with video. Think of a video like a flip book, each frame is a photograph, 1 every 30 milliseconds, setting the shutter to 1/60th of a second will allow an exposure time of just 16.66 milliseconds for each photograph, this is just enough to create a small amount of motion blur between each photograph that when played in a sequence wont be noticeable but creates a smooth effect between each photograph for anything moving. Objects that don't move much will retain sharpness. Because your drone has a stabilised camera and its subjects tend to be much further away they will retain more detail. If, as you say, you point the camera at the ground and fly forward at speed, you will get a very blurry image indeed. If you were to fly low to the ground with the camera tilted down slightly, the horizon and objects in the distance would appear sharp while the ground and subjects moving toward the camera would slowly become more blurry.
The 180 rule is great for creating cinematic looking footage but it's not really a rule. You can use the shutter for any creative effect. For example, shooting at 30fps and a shutter speed about 90 creates an effect mostly used in action sequences in movies, a small amount of stutter to break up the motion blur creates almost a nightmarish feel, like the story is flashing before your eyes. Shooting at 60fps and a shutter of 120 allows you to slow footage down by half to 30fps and keep that cinematic movement while creating a pleasing effect of seeing something in slow motion, great for shots flying over a lake where a bird might be taking off. You could even do 240/500 for a super slow motion while retaining that cinematic look if your drone has that feature.
Seeing talk of ND filters is a good point, all the ND filter is for is to allow you to expose your image based on a fixed shutter. If its a bright day you might need a stronger ND filter. Shooting at higher shutter speeds, you might not need one at all.
experiment and have fun |
