Fantomgep
Flight distance : 30594 ft
Hungary
You can link the mavic2 pressing the link button on the side. On the smart controller you have to use the aircraft add icon on the aircraft managemnet menu.
Switching between the binded crafts is also tricky. The startup screen does not show the bided aircrafts. Maybe it is a bug, but if you sweep down and select the setting menu/aircraft management , you will see a paired aircraft with its name. Tapping the proper icon the controller will switch without any issue.
You mantioned that you experienced craches of the djigo4 app with the lastest fw. Sad to say, but it seems a valid issue. Many of users report occasionaly app craches mainly go4, but there are issues regarding to djiflyapp also (laggy fpv view). With the previous fw version (***700) everything works perfectly, but this version not supports the air2.
Some users reported that a factory reset BEFORE the fw update of the latest fw solved the problem.
