hello i just received my dji rsc2 bundle package with the focuse motor and raven eye. when i go to auto tune it the error message is unable to calibrate gimble when handle is folded? can you clarify what handle? also when i go to calibrate the focus motor it says focus motor timed out after calibration? how can i fix these errors? i dont see any tutorials for the rsc2 regarding the focus motor or raven eye?
I was able to get the gimbal lock fixed. when I turn on the app I can see my camera in the app and view what my camera sees. the info provided for the focus wheel does not match the focus wheel received there is no focus wheel multifunction button per the instructions provided. also when I turn on the camera to the raven eye it says camera not connected? I can see the camera in the app so it is connect. also how do I calibrate the focus motor? how do I set the points? is it through the app? the problem I have now is the focus motor calibrating and the app saying the camera is not connected when it is and I can see the image.
I had the focus motor problem too. The instructions refer to the RS2 not the RSC2. Basically you use the in-built focus wheel to turn the focus ring to its max in both directions. Hold the wheel until you feel the force stop. That's the calibration end stops done. If you have a focus wheel or zoom wheel that does not stop you have to hold the ring stationary at its end stop to simulate and end stop. I hope this makes sense.
CockneyUSA Posted at 11-3 11:19
