djiuser_Tt0L4MFPsziE
Flight distance : 1742103 ft
I only had time for a few short quick test flights since launch date and now after some update, I go for the first real voyage and I'm losing signal after about 100 - 200 feet away. It does engage the return to home and the signal returns within a few seconds and displays the error ' The camera restarted abnormally...'.
Is this a known issue or is my Mini 2 just broken?
Update...
I'm using a Samsung Galaxy S20 FE that is update to date, just got it a few weeks ago. I checked the flight logs on the phone and the strange part is that it only contains the flight logs from the RTH part and not the initial part of the flight before losing connection. I was able to capture this info from the Data Center info the DJI Fly app.
Flight 1 - Only 23m away and 47m altitude. 2 errors displayed, luckly the drone RTH safely.
Error 1 - Aircraft not connected to RC - Also Chinesse error
Error 2 - The camera restarted abnormally... - Also Chinesse error
Flight 2 - Only 0.5 m away and 44m altitude. 2 errors displayed, luckly the drone RTH safely.
I had a few other flights with the same issue, I have calibrated the Compass, IMU, and Gimbal.
Here is my version info.
Anyone else having these issues? It's a a bit concerning since control of the aircraft is lost at such a short distance. Luckly, the drone does go into RTH mode, but with the camera error and the strange Chinesse error, the GPS could also error out as well and cause a fly away. Any help will be appreciated.
