ABeardedItalian
Flight distance : 1063107 ft
DJI Paladin Posted at 11-6 14:51
Hello sergeant, I appreciate the video you have shared and thank you for reaching us out. The Mavic Mini Intelligent Flight Battery of the international version of Mavic Mini are compatible with the international version of DJI Mini 2. Although the international version of DJI Mini 2 can use Mavic Mini’s battery, the power will decrease and the total weight will exceed 250 g, requiring registration in some countries and regions. Please check local rules and regulations before use. Thank you for your support.
You guy's need to remove International JP part, everyone who's doing these tests are using the 249g mini 2. Clearly it works, but it will require you to register it. So unless they are planning to patch the normal mini 2 to prevent users from doing this, the only hiccup is the additional weight and requiring to be registered.
